Activity Forums VEGAS Pro nested section stops render
  • nested section stops render
    Posted by Steven J casey on May 24, 2013 at 3:07 pm
    Working on a slideshow project for a friend. At one point he asked if one group of photos could go through the end of one particularly song (moving some photos into the following song), which meant stretching them out time-wise to fill the first song. Instead of going through each photo to lengthen, I nested that section and time-stretched it. Plays back perfectly. Problem is when I try to render, Vegas just stops when it hits that section. Not a complete crash, just stops. Anyone ever had this happen with a nested comp? I don’t understand how it could play back perfectly but not be able to render.
    thx
    Dell Precision T7500
    Intel Xeon CPU X5650 @ 2.67GHz 2.66 GHz (2 processors)
    60GB RAM
    Quadro 4000
    Windows 7 Ultimate
    CS6
    M-Audio FW 410
    Vegas Pro 12
    Steven J casey replied 13 years, 3 months ago 2 Members · 2 Replies
  • John Rofrano
    May 25, 2013 at 2:31 pm
    Yea, I’ve seen rendering stop like this before and it’s usually fixed by going into Options | Preferences | Video and disable GPU Acceleration.
    BTW, you didn’t have to use a nested project. You can select all of the pictures and press the ‘G‘ key to Group them and then drag the end of the group and all of the pictures will lengthen accordingly.
    You can also use a script plug-in like VASST Still Motion for $9.95 USD and change the lengths and a whole lot more with a single click.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steven J casey
    May 26, 2013 at 3:13 pm
    Thanks John!
    60GB RAM
    Quadro 4000
    Windows 7 Ultimate
    CS6
    M-Audio FW 410
    Vegas Pro 12
