Activity › Forums › VEGAS Pro › Nested project – no update in the master project
  • Nested project – no update in the master project
    Posted by Guillaume Jeffrey on March 28, 2011 at 3:03 am
    Everything is in the subject.
    I have a master project composed of 3 nested projects. When I modify one of the nested project (right click edit in…) and save my changes, there aren’t any update in the master project. To get the changes I have to close the master project then open it again.
    Is it normal?
    I’m using Vegas pro10c 64bits, windows7 64bits.
    Guillaume Jeffrey replied 15 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Nigel O’neill
    March 28, 2011 at 12:18 pm
    The behaviour you are observing is correct. The changes are not dynamic, in that editing the nested project will not immediately result in the master being updated if all are open simultaneously.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Mike Kujbida
    March 28, 2011 at 12:44 pm
    I use the 32 bit version of Vegas but I have never had this problem.
    While working on a project, I can open a nested veg file, save the changes and the current project is instantly updated without me having to do anything else.
  • Guillaume Jeffrey
    March 29, 2011 at 12:51 am
    So what is the correct behaviour? Automatic update or not?
    Should I report this this as a bug?
  • Mike Kujbida
    March 29, 2011 at 9:40 am
    I was hoping for feedback from other users.
    I consider this to be a problem with your system and not a bug as, contrary to what Nigel said, it has always worked for me.
  • Theo Van laar
    March 29, 2011 at 11:23 am
    My experience with changes in nested projects is that they update immediatly.
    Theo
  • Guillaume Jeffrey
    March 30, 2011 at 1:08 am
    Thanks for your feed back Mike.
    What are the problem with my system?
    My master project is a simple 6min video composed of 3 nested projects of approximately 2min each. All the videos are from a sony Z7, HDV 1080-50i. No fancy effect except few color correction.
    I am editing this movie on laptop i7-720qm – 6gb memory (may be the reason??).
    I have tried using the 32bits version of vegas, the master project doesn’t update as well.
  • Mike Kujbida
    March 30, 2011 at 1:34 am
    Guillaume, I have no idea what to tell you.
    Have you tried it with just a single nested veg?
    Start a new instance of Vegas, add only one of the veg files and see if you can get it to work properly.
  • Guillaume Jeffrey
    March 31, 2011 at 3:29 am
    Sorry Mike, it’s my mistake. In preferences the “close media when not active application” was unchecked.
    Update of the master project works perfectly when it’s checked.
  • Mike Kujbida
    March 31, 2011 at 10:21 am
    Guillaume, I never would have guess that as being the problem.
    Thanks for letting us know what the solution was.
  • Guillaume Jeffrey
    April 1, 2011 at 5:57 pm
    Mike, this forum has been so helpful to me even though I haven’t post a lot, i’d like to share the little I know for the others.
