Activity Forums Adobe After Effects Nested pre comps not showing up when exporting.
  • Nested pre comps not showing up when exporting.
    Posted by Gel Dandilion on December 10, 2012 at 5:38 pm
    Hello all.
    Im sure there is a simple answer to this but its been driving me insane. Ok so here it is…
    I shot some footage using three cameras. I created 3 compositions, one for each cam so i could have different adjustment layers over each without them effecting each other (as each cam needed to be coloured etc slightly differently). I then nested the second and third into the first composition.
    However, when i exported all this through media encoder the nested footage was missing. There was just a blank screen. The footage was there when i checked the output preview in media encoder which makes it even more frustrating.
    I only realised this when i went to burn the afore mentioned footage in Encore. I have absolutely no idea what to do! Any help will be greatly appreciated. 🙂
    Kind regards,
    Greg
    Gel Dandilion replied 13 years, 9 months ago 45,285 Members · 2 Replies
  • Gel Dandilion
    December 10, 2012 at 9:27 pm
    Hi Dave,
    Thank you for the quick reply. Hmm good idea about the master comp, ill give that a go. I usually would do things the way you suggested, keeping everything in a single comp and applying effects individually, however in this footage there about about 200+ cuts to the 3 cameras, so Im trying to make a more efficient workflow. Though to be honest if id have done it that way in the first place it would have been done by now. Anyway ill give your suggestion a go and let you know if it works. Thanks again!
    Greg
  • Gel Dandilion
    December 10, 2012 at 10:21 pm
    Yeah it was for a wedding ceremony that went on for quite some time, two un manned cameras and one manned. I split the clips up and jumped between the three in premiere to stop things from becoming stale.
    Your first idea worked! All it needed was a ‘master’ comp to nest the pre comps in. Thank you very much indeed. Happy holidays!
    Greg
