Activity Forums Adobe After Effects nested comp colour shift?
  • nested comp colour shift?
    Posted by Peter O’connell on May 20, 2005 at 6:24 am
    Hi I have 3 layers in a 10 layer comp that I made into a nested comp. There seems to be a colour shift between the three layers in the original comp as compared to the same 3 layers which make up the nested comp, Mostly I am seeing a darker edge. Does anyone know what I am doing wrong?
    Pete
    Peter O’connell replied 21 years, 3 months ago 3 Members · 3 Replies
  • Mylenium
    May 20, 2005 at 9:18 am
    Maybe you’re using a diffrent pixel aspect in on of your comps? Or some kind of blur or other effect was applied to one of the layers and now affects the entire sub-comp?
    Mylenium
    [Pour Myl
  • Andrew Yoole
    May 20, 2005 at 1:46 pm
    If there is any level of transparency in your precomp and the background colour of one comp is different to the other, you’ll notice the colour difference.
  • Peter O’connell
    May 20, 2005 at 8:40 pm
    Thanks guys looks like it was a background colour problem.
    Cheers
    Pete
