Activity Forums Broadcasting Nervous about my first broadcast delivery.
  • Nervous about my first broadcast delivery.
    Posted by Mike Edge on February 26, 2009 at 11:15 pm
    I shot an infomercial for a local company that will be broadcast on a number of stations throughout the area. I used a Panasonic HVX-200a with all footage being shot in 720/30p and downconverted to SD 720×486 in After Effects (since 99% of the footage involved a green screen).
    My current plan is to export each scene from After Effects as a Quicktime (animation codec), import them into an 8-bit uncompressed sequence in Final Cut Pro, and piece them together for export to Digi Beta tape. I haven’t exported anything to tape since some MiniDV projects in school am wondering if there’s anything I should keep in mind/look out for. One thing I was specifically wondering about was interlacing. All my footage is currently progressive but I’ve read some places that I’ll need to introduce interlacing prior to exporting to Digi Beta. Is this true (and if it is, how do I do it)?
    Any other help/tips/suggestions would be greatly appreciated.
    Mike Edge replied 17 years, 7 months ago 1 Member · 1 Reply
  • Mike Edge
    February 26, 2009 at 11:34 pm
    Thanks for the quick reply, Dave.
    First of all, I should have clarified and said that I was rendering from After Effects and not exporting. I know they’re separate things but I sometimes mix up the terms. I’ve seen you drill it into people on here before so I really should have known better.
    As far as the card goes, I don’t personally have one. I have a friend that works at a large commercial production company with a big edit suite that’s set up for Digi Beta and I’m planning on taking my footage there to transfer it. I’m not sure what card they have, but I could find out if it’s something I’d need to know in advance.
