Activity Forums Adobe Photoshop nerds to attention!
  • nerds to attention!
    Posted by Alex Harding on January 12, 2006 at 1:16 am
    im doing a batch action comman on an image sequence. the images are tif’s. the action involves generating an alpha chanel. the problem: every time photoshop saves an image it comes up with a dialogue box requesting me to manually specify the tif options; i have to do this for every single file. there are thousands. is it possible to make photoshop remember the tif options (compression, transparency, preserve layers etc) or am i going to have to approach this from a diferent angle?
    cheers,
    alex
    Richard Harrington replied 20 years, 8 months ago 2 Members · 1 Reply
  • Richard Harrington
    January 12, 2006 at 1:25 am
    Either record the close and save as part of the step and check the ignore Save As in the Batch or use the Image Processor Script with CS2 and specify to include the action in the save
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
