Activity › Forums › Adobe Premiere Pro › Neon light, inappropriate shutter and ever-changing white balance.
  • Neon light, inappropriate shutter and ever-changing white balance.
    Posted by Charles Burrows on October 30, 2012 at 4:19 pm
    Hi everybody,
    Last week I’ve recorded a video with my AG-HPX171E in a place lighted by neon lamps. Unfortunately, the camera’s shutter speed was inappropriate. Thus, the video has a continuous change in it’s white balance from warm tones to cool tones and turn back again and again until the end of the timeline. This issue was warned by the manual of the camera, but now…
    …Is there any solution to harmonise or standarize the white tone along the video? Something that could eliminate those peaks of warm balance and cool balance, al let it be something intermediate all long the video.
    Thanks a lot in advance.
    Greetings!
    Tim Kolb replied 13 years, 10 months ago 3 Members · 3 Replies
  • Ann Bens
    October 30, 2012 at 6:42 pm
    Nope, you will have to cut the clip up in segments
    Correct the warm tone and cool tone separate.
    If they are all the same you could use copy/paste attributes on remaining clips.
    Use cross dissolve to ease the changes.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Charles Burrows
    October 30, 2012 at 7:11 pm
    Ok,
    Thanks a lot for your answer!
  • Tim Kolb
    November 4, 2012 at 11:17 pm
    You could use a color corrector filter like the fast color corrector and keyframe the white balance over time.
    With these types of situations (a stage spot with a failing bulb or power ballast can do it as well), the color shift is continuously changing, so sectioning the clip and assigning unchanging white balance values will give you very obvious cut points in most cases.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
