Activity Forums Adobe After Effects Expressions Needs of cycle or reset expression for an offset (Roughen Edges)
  • Needs of cycle or reset expression for an offset (Roughen Edges)
    Posted by Santiago Suarez on June 24, 2020 at 7:17 pm
    Hi, I have this scenario:
    I have a simple bar made with a box Shape layer. To get fancy i added a Rough Edges effect (RE).
    Then i animated the height of my box but the RE remains static, so no problem, i linked by expression the Y Offset of the RE to the height of the box, and works great, it gives the illusion of move accordingly to the growth of the bar.
    The problem came when i noticed that the RE has an offset limit of 32000 pixels, so when the height of the box exceed this amount (and it does by a lot), the RE stop moving, losing the illusion.
    So, my idea to solve it, is to get a kind of expression that reset the RE offset every time the height’s box gets 32000 or a multiple of it, and start from zero again but still linked to the growth of the bar. I think that this can still maintain the illusion of movement.
    So if you could help me with this expression or with another solution, i will apreciate.
    //code to link RE Offset to box height
    x = value[0];
    L = thisLayer;
    y = L.sourceRectAtTime(time-L.inPoint).height;
    [x,-y*5];
    Santiago Suarez replied 6 years, 2 months ago 2 Members · 4 Replies
  • Andrei Popa
    June 25, 2020 at 7:23 am
    Try this:
    x = value[0];
    L = thisLayer;
    y = L.sourceRectAtTime(time-L.inPoint).height%32000;
    [x,-y*5];
    Andrei
    My Envato portfolio.
  • Santiago Suarez
    June 25, 2020 at 3:28 pm
    Hi Andrei, thank you for reply
    It worked really nice, i had to make a minor adjustment but the approach was pretty effective.
    If you don’t mind i would like to understand why this %32000 works, i’m not a very Code man, but i like to understand this simple concepts that probably would help me in the future.
    ///////The code you gave to me
    x = value[0];
    L = thisLayer;
    // Previously I multiplied the offset by 5 at the end
    [x,-y*5];
    ///////The code updated
    x = value[0];
    L = thisLayer;
    // I had to multiply by 5 before add %32000, other wise the offset get a little crazy
    y = (L.sourceRectAtTime(time-L.inPoint).height*5) %32000;
    [x,-y];
  • Andrei Popa
    June 25, 2020 at 3:33 pm
    It’s called modulo operator. It is what left when you divide it by that number.
    Eg: if you divide 5 by 2, it is 2 and 1 left. So 5%2 is 1.
    You use this operator when want to create a cycle. time%10 would start from zero to 10. Then the second it hits 10, starts from zero again. Because 10%10 is 0. And again at 20 and so on.
    Andrei
  • Santiago Suarez
    June 26, 2020 at 3:40 am
    Thank you very much Andrei, for the solution and for the explanation.
