Activity Forums Adobe After Effects Needing some pro advice
  • Needing some pro advice
    Posted by Lisa Simonson on September 28, 2011 at 7:55 pm
    I’ve run into a snag with this shot.
    Explosion reflection in goggles with slow dolly into C.U., one lens.
    I’ve tried alpha mask w add blending mode , color key, track mats, gradient mask,lots of things, yet every time I render the explosion seems to float on top. Not natural looking, The explosions are alpha channels. Any tips or ideas? Is it OK to post a still?
    Sean Mullen replied 14 years, 12 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ben G unguren
    September 28, 2011 at 8:12 pm
    Is this a compositing problem, or it is a movement problem, or both?
    If it’s compositing, posting a still will be very helpful.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Sean Mullen
    September 28, 2011 at 8:19 pm
    Have you tried blending the bg of the goggles back over the explosion element? You could also track in a light reflection over the explosion as well. Like Ben said, it would be easier to identify with a still or clip.
    Sean Mullen
    Rampant Design Tools
  • Lisa Simonson
    September 28, 2011 at 8:31 pm
    Here is a mock up I did in photoshop.
    The mask isn’t that difficult. Unfortunately there is a slight curve with the dolly in. When I animate the mask its really aweful. Like a bad rotoscoping job.
  • Sean Mullen
    September 28, 2011 at 8:37 pm
    Ok I see. I’d recommend feathering your mattes and if you are hand tracking them, to do at least every 3-5 frames (if not every frame, depending on the move) I’d also lower the opacity of the reflection a bit, blending in the goggles more. Try also putting a slight blur on the elements you are compositing.
    Sean Mullen
  • Lisa Simonson
    September 28, 2011 at 8:44 pm
    Oh! So hand tracking should be more frequent it seems. I was hand tracking about every 15-20 frames. Probably why it looked so jumbled. Will lower the opacity and use slight blur.
    great, thanks!
  • Ben G unguren
    September 28, 2011 at 9:31 pm
    A mocha track wouldn’t take long and might make a big difference over hand tracking. Then again, hand tracking has a certain appeal to it as well. But if the child is making any kind of small movements, the hand tracking tends to miss it.
    Ben Unguren
  • Sean Mullen
    September 28, 2011 at 9:33 pm
    I agree completely, I rarely hand track. It’s easier to remove keyframes from a Mocha track for a looser feel than it is to refine a hand track, in my opinion. Mocha should be able to attack this fairly easily.
    Sean Mullen
