Activity Forums Sony Cameras Need XDCAM driver
  • Need XDCAM driver
    Posted by Joseph Colombatto on May 12, 2011 at 7:54 pm
    Am running Snow Leopard on Mac Pro (mega ram), and am trying to connect EX3 with FCP 7
    thru firewire.
    Downloaded XDCAM Transfer version 2.10, but it says I need a XDCAM Drive software.
    Why didn’t that come with the download?
    Anyway, do you have a direct URL link where I can download this driver and which one?
    Very Confused.
    Daniel Wright replied 15 years, 4 months ago 4 Members · 5 Replies
  • Craig Seeman
    May 12, 2011 at 8:09 pm
    If you’re transferring recorded files you should be using USB or Sony’s Express card reader to USB.
    XDCAM Transfer should be version 2.12 and ClipBrowser 2.6. Always copy using ClipBrowser with CRC on. You shouldn’t need the driver unless you’re using Express port on MacBookPro (or Windows equivalent).
  • Ed Stahr
    May 13, 2011 at 2:02 pm
    Hereʻs a helpful tip: The Canadian Sony Pro site is much easier to find and download software from than the American site.
    https://support.sonybiz.ca/esupport/init.do
    The drivers/firmware are all found through that page, follow links in left column to find the one you need.
  • Joseph Colombatto
    May 13, 2011 at 5:08 pm
    Thanks.
    I loaded in XDCAM Transfer v2.12 and also FAM driver Tool 2.3, but XDCAM Transfer is asking for
    XDCAM Drive Software.
    Isn’t that what FAM does?
    Thanks.
  • Craig Seeman
    May 13, 2011 at 5:24 pm
    Install ClipBrowser 2.6 please.
    You don’t need the driver if you’re not using a laptop.
  • Daniel Wright
    May 14, 2011 at 10:01 pm
    I’m presuming that you are looking at XDCAM Transfer’s ‘Installed Components’ window. This tells you what you need for *absolutely everything* to work. If you click on an item in the list, XDCAM Transfer tells you what its for below.
    You don’t necessarily need to install everything in that list; you only need the XDCAM Drive software if you are using a PDW-U1.
    HTH
