Activity Forums Apple Final Cut Pro Legacy Need wisdom on organizing project with media dating back 10 years.
  • Need wisdom on organizing project with media dating back 10 years.
    Posted by Hayley Downs on December 21, 2010 at 9:45 pm
    Hi there. I’m working in Final Cut 6.06.
    The project I’m working on consists of footage dating back more than 10 years. A consistent naming convention came later so the earliest footage is named in many different ways but now I need it to be consistent. I need to clean up the project in preparation for the edit and I have a couple of questions:
    1. For the oldest tapes, the video and audio tracks are split out in the media. I’m not sure why this happened. Is there a way to fix so that the media audio and video are merged into one file?
    2. I need to rename the clips in about 35 tapes to conform with the rest of the project. But there are sequences already built with the existing names. How can I get the sequences to update to match the new names?
    Hayley Downs replied 15 years, 9 months ago 2 Members · 3 Replies
  • Hayley Downs
    December 21, 2010 at 10:24 pm
    Hi David:
    The tapes are all mini dv. 29.97/DV/DVCPro NTSC. It’s a documentary that is part “diary film”. So many of the tapes were shot for home use or for different film projects. They were all originally brought into a series of different Final Cut projects. (never Media 100)
    They have now all been brought in to one big project but they have different naming conventions. I can change the names of the files to match the clip and I have figured out how to update the sequences that include old clip names.
    The problem is that the first 25 tapes appear to be “merged” clips. The video (quicktime) and the audio (Aiff) are separate files on the hard drive. Can I merge them so that they are one file or am I stuck re-batching the first 25 tapes?
  • Rahul Duggal
    December 22, 2010 at 2:41 am
    I think if you physically need to get the Audio & Video clips into a single file there is no way out but to re-render. On another note (if the source files & their composition are not important to the final outcome of the project) you could skip the re-rendering part and be happy by putting the audio & video in sync & just linking them instead. (FCP will treat them as a single ‘Linked’ Audio/Video file).
  • Hayley Downs
    December 22, 2010 at 3:16 pm
    Hi. Thanks for responding. When you say “re-render” do you mean re-batch digitized? As for the clips, they are already linked. It’s just that they show up as two sep. files on the hard drive. For instance, one would be sampleclip-v and the other sampleclip-a
    I can’t change the names of both clips to be consistent with the rest of the project and relink when I change their names.
