Activity Forums Adobe Encore DVD Need Urgent Help, Importing Mov into Encore, Resolution must be 720×480….
  • Need Urgent Help, Importing Mov into Encore, Resolution must be 720×480….
    Posted by Jana on April 14, 2005 at 1:15 pm
    I am using CCE SP 2.67, i dont understand why its not importing? Is there a quick way to check the resolution or change the resolution ( I am using avid and i can change the resolution, but the quality is horribly dropped)
    any suggestions?
    thanks in advance!
    jana
    Roadkill replied 21 years, 5 months ago 3 Members · 2 Replies
  • Tim Kurkoski
    April 14, 2005 at 3:10 pm
    Assets must be DVD-ready when you import them into Encore (save for whether or not they’re MPEG-2, which Encore can transcode to). That means they must be the correct dimensions and frame rate, etc. I’m not familiar with Cinemacraft, but I fully expect that they have preset options for encoding to standard NTSC (720×480, 29.97) and PAL (720×576, 25) dimensions and frame rates. This shouldn’t be a problem coming from Avid.
    Out of curiosity, what dimensions and frame rate are you using now?
  • Roadkill
    April 14, 2005 at 4:35 pm
    A quick way to check would be with Bitrate Viewer or of course in the settings of CCE SP.
