Activity Forums VEGAS Pro Need ugent help rending in BD
  • Need ugent help rending in BD
    Posted by Paul Gilmore on June 21, 2009 at 8:31 pm
    I already posted this on another forum however I wanted to see if anyone else had any other suggestions:
    I upgraded to Vegas pro9 and I bought a LG BH0B BD burner. Last night I tried burning my first BD DVD. When I looked under the templates I noticed many diffrent BD choices and I was unsure which to choose so I made the decision to rendered in 1920×1080-24p. 25Mbps video stream and burned in DVDA under make BD DVD. It finished burning, however it seemed very quick to burn. Anyways when I inserted the dvd into my BD DVD player the DVD will not play and when I insert it on my computer it will not play either. I thought perhaps it did not burn so I tried to burn it again and it says “This is read-only, please insert a rewritable disc” when I tried to burn it again
    What am I doing wrong? any suggestions would be much appreciated! I did upgrade my DVD player to the current firmware update and my player plays BD-R so I don;t think it;s the player. Could it it have been burned incorrectly since it says read only?
    Please help me thanks!
    Paul
    Paul Gilmore replied 17 years, 2 months ago 3 Members · 4 Replies
  • Joe Parker
    June 22, 2009 at 2:48 am
    Look at the disk in explorer. Is it a blu ray or a dvd or what (i.e., does it have .ifo files?). Tell us what the file structure on the disk is.
  • Paul Gilmore
    June 22, 2009 at 10:25 pm
    When I explore the disc in the DVD drive it’s blank and says 0 items in the bottom left corner. When I click on properties it shows the disc is full.
  • Nigel O’neill
    June 23, 2009 at 1:03 pm
    You might want to try ‘Prepare’ first instead of ‘Burn’ to see if files are being created in the first place.
    My first Blu-Ray project (2.5 hours of 1440x1080i HDV edited m2t’s) took 15 hours to prepare and about 1 hour to burn on a 2X RE disc.
    Do you need to format your BD disc first? Some discs like the RE’s are rewritable.
  • Paul Gilmore
    June 23, 2009 at 3:52 pm
    I will try that, thank you.
    let you know if it worked,.
