Activity Forums Adobe After Effects Need to upres – DV to 2k!
  • Need to upres – DV to 2k!
    Posted by Benj Roche on January 13, 2009 at 7:37 pm
    Is there a simple way to upres a composition?
    I have put in opening titles for a feature film. We have been working offline so everything is DV res. Now we are onlining the film and preparing for a film out. I need to have the titles ready to go and I am no sure how to proceed.
    Adam Mercado replied 17 years, 7 months ago 3 Members · 3 Replies
  • Will Cavanagh
    January 13, 2009 at 8:10 pm
    Depending on how things are set up (and what you have going on in your comps) it can work to make a new comp at the res you need to output, put your old comp in it, scale your old comp up, and check the “Collapse Transformations” flag. This can also make things break…
    I believe that replacing any footage files (in the Project right click on the footage and choose “Replace File”) with full res sources will work (although you may run into Anchor Point issues in your comps.)
    It’s usually a good idea to work in the final res from the start (even if you never RAM Preview at full res), and output proxies for the NLE if they’re doing an offline.
  • Benj Roche
    January 13, 2009 at 10:27 pm
    Cool i will give this method a shot. When I say opening titles I mean just titles – vector text with a simple blur/fade out. I plan on just exporting the clips with alpha channels so they can be added to the online.
  • Adam Mercado
    January 14, 2009 at 5:55 am
    there was a plugin by Digital Anarchy called Instant HD. DA got bought by Red Giant so not sue if it still exists. Supposedly it had very effective algorithms for upscaling.
    Adam Mercado
    Influxx Media Production
    Motion Graphics & Video Post Production
    Fullerton, CA
