Activity Forums Adobe After Effects need to select keyframes on hundreds of layers
  • need to select keyframes on hundreds of layers
    Posted by Riccardo Sinti on October 7, 2015 at 8:53 pm
    i have hundreds of layers and want to select keys on all of them but don’t want to drag and scroll across all those layers.
    1. is there a way to select every layer’s keys on a certain property?
    or ever just the property itself?
    2. is there a script that will select every visible or hidden key across all selected layers either at time or within work area?
    thanks!
    Ashish Gupta replied 10 years, 11 months ago 2 Members · 1 Reply
  • Ashish Gupta
    October 8, 2015 at 8:37 am
    You can simply press U in the comp to reveal all the keyframes on all layers, then press Ctrl+Alt+A to select all the visible keyframes.
    Alternatively, Press the shortcut for the property, say P for position to reveal position for all keyframes, then use the same shortcut to select all visible keyframes.
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
