Activity › Forums › Adobe InDesign › Need to rescale the whole content of a document
  • Need to rescale the whole content of a document
    Posted by Emre Soyak on March 11, 2010 at 3:38 am
    Im currently facing a problem. There is a a4 sized pdf design that just “fit” to a4. But this document will be sent to print. So this document has no space to spare like no mark for blades.
    So instead of doing it all over again – i need to rescale or resize the whole content of the document so that ill receive space from top- bottom and left or right (based on which side it is).
    What should i do? Thanks in advance.
    Terry Mikkelsen replied 16 years, 6 months ago 2 Members · 1 Reply
  • Terry Mikkelsen
    March 16, 2010 at 8:33 pm
    Make a new Indy document at the size you want it to be. Then place your previous Indy document into it (just as you would place a jpg or pdf). Pressing the “e” key, will select the free transform tool in which you can alter at will your placed “image” to the size you desire.
    Tech-T Productions
    http://www.technical-t.com
