Activity › Forums › Adobe Premiere Pro › Need to remove backround music in Premiere Pro2
  • Need to remove backround music in Premiere Pro2
    Posted by Doron Martin on December 21, 2007 at 10:19 pm
    I have footage of actors doing dialogue.Unfortunately the studio below mine blasted their music and now my video has it in the backround.How can I take this out while keeping the actor’s dialogue intact?
    Jon Barrie replied 18 years, 9 months ago 3 Members · 2 Replies
  • Ann Bens
    December 21, 2007 at 11:08 pm
    You need Soundbooth. Premiere is unable to do this for you.
  • Jon Barrie
    December 22, 2007 at 7:15 am
    This is when you stop the shot and reshoot the scene. Hence the term “Quiet on set!”. If you have music blasting over dialog you are fighting an uphill battle not worth fighting. Better to ADR it or use dialog from another take and match it as best as possible to the timing of when the actors said it in the original. Use the waveform to sync the audio files and unenable the chunk with music to ‘turn it off’. CLick the little triangle on the top right of the timeline to select show audio timeline units to work in the Khz range instead of fps you’ll get an accurate sync this way. (change it back when done!)
    – Jon 🙂
