Activity Forums Maxon Cinema 4D Need to relaod audio into effector
  • Need to relaod audio into effector
    Posted by Andrew Wagstaff on May 31, 2026 at 10:51 am
    Whenever i am working with audio files i always have to reload them into the scene when i reopen the project
    is there a way to stop this from happening its not much of an issue when its one or two but when you have more it becomes tiresome
    Kouraib Abdmalek
    replied 2 months, 3 weeks ago
    2 Members · 5 Replies
  • Kouraib Abdmalek
    June 1, 2026 at 9:17 am
    Hi Andrew,
    You shouldn’t need to re-load the audio file every time. I don’t recall ever having to. I tested it again, as in the recording below, and the audio file remained in place even after closing the program. Your files might have some specific settings. If you could share an example of a file where this problem occurred, that would be helpful.
  • Andrew Wagstaff
    June 1, 2026 at 3:28 pm
    I use the WAV format when i reopen the scene all i get is static as shwon in the video
    https://www.youtube.com/watch?v=7xcGOJYoVPg
  • Kouraib Abdmalek
    June 2, 2026 at 9:47 am
    I apologize in advance if I didn’t understand, but I see in the video that when you opened the file, the audio file was in its place and didn’t need to be re-loaded. Please correct me. Secondly, does this problem only occur with WAV files? Have you tried other formats?
  • Andrew Wagstaff
    June 2, 2026 at 11:07 am
    the audio file appears to be in place but when i scurb through the time line all i hear is static until i reload the audio file, i have tried it wi aiff and mp file formats and get the same problem
  • Kouraib Abdmalek
    June 3, 2026 at 9:51 am
    I tried to simulate your scene’s using various effects, and the motion and other effects remained the same; I didn’t need to re-upload the audio file. The problem might be with the version you’re using, and it seems to have been resolved in newer versions, as it was for me. Alternatively, the issue might be with the version on your device itself due to missing system files. You can check this by opening your file in another computer, or you can simplify the file by deleting anything you don’t want to share with us. I’ll examine the simplified file to determine the cause of the problem. I hope this helps.
