Activity Forums Adobe After Effects Expressions Need to mix a linear expression with a time offset from another comp expression
  • Need to mix a linear expression with a time offset from another comp expression
    Posted by David Cabestany on February 17, 2017 at 3:24 am
    Could anyone help me combine this two expressions together?
    Basically I need a linear expression to occur based on the keyframes from another comp. However the inside comp it’s a seamless particle loop, so while it’s ten second long, the in point in the outer comp is at the 5 second mark.
    Does this make sense?
    Thanks everyone.
    D.
    C = comp("poster-el protector COMPED");
    L = C.layer("poster-el protectorAE2");
    ctrl = C.layer("poster-el protectorAE2").effect("FL Out Of Focus")("radius");
    k1=C.layer("poster-el protectorAE2").effect("FL Out Of Focus")("radius").key(1).value;
    k2=C.layer("poster-el protectorAE2").effect("FL Out Of Focus")("radius").key(2).value;
    ctrl.valueAtTime(time+L.startTime)
    linear(ctrl,k1,k2,k2,k1);
    David Cabestany replied 9 years, 7 months ago 1 Member · 1 Reply
  • David Cabestany
    February 17, 2017 at 4:02 am
    Got it, in case anyone needs it:
    ctrl = comp("poster-el protector COMPED").layer("poster-el protectorAE2").effect("FL Out Of Focus")("radius");
    L = C.layer(thisComp.name);
    x=ctrl.valueAtTime(time+L.startTime);
    linear(x,0,63.5,650,0)
