Activity › Forums › Adobe Encore DVD › Need to make my file smaller
  • Need to make my file smaller
    Posted by Mechelle Morris on April 1, 2010 at 4:53 am
    I am a film student and I used CS4 Encoure along with Premeire Pro for an Animatic I had to make for an assignment. I made a slide show in Encoure with Pans and Zooms and then brought it into Premiere to add sound effects along side of music. I then made my project into a Quicktime movie, but the file was 1.34 GB. I need 100kb to be able to send it to my teacher and he wants a quicktime movie. How can I do this without redoing my project? My teacher said I probably had my pictures too big.
    Clint Milner replied 16 years, 6 months ago 2 Members · 1 Reply
  • Clint Milner
    April 1, 2010 at 12:18 pm
    I don’t know if you have any experience with After Effects, but here’s a really good Slide Show tutorial that may help reduce your picture size as well as your project size. This solution is a bit more elegant than the Encore version way and you can add the audio in the After Effects timeline at the same time so you don’t have to take it to Premiere too.
    https://www.videocopilot.net/tutorials/elegant_slideshows/
    If you can’t use the tutorial, I guess the only option would be to change the Export settings in Premier. Changing the dimentions and/or quality of the render should help to reduce the size.
    Hope that helps.
    Clint
    Adobe CS4 Master Suite
    Vista Ultimate 64 SP1
    Intel Core i7 920 @ 3.60GHz
    12 GB DDR3 RAM
    NVidia Quadro FX 3700
    Matrox RT.X2 LE Capture Card
    4 TB RAID 5
