Activity › Forums › Avid Media Composer › Need to make an ‘eye twinkle’ effect
  • Need to make an ‘eye twinkle’ effect
    Posted by Sara Hutchinson on May 1, 2010 at 1:39 am
    Exactly as the subject!
    I need to make a character have a literal twinkle in the eye in a short i’m cutting, but have no clue. Instead of stumbling around the FX palette i figured i’d try my luck here!
    I’ve got Avid Media Composer 4.0 with Boris BCC. Annoyingly tho, none of the OpenGL FX will work – that’s an issue i’m also addressing, but the eye twinkle is more pressing!
    Any help is really appreciated!
    Sara
    Matt Mullen replied 16 years, 4 months ago 4 Members · 3 Replies
  • Grinner Hester
    May 1, 2010 at 11:10 pm
    Cheezy is usually the goal here so I’d make the star in photoshop, import it with an alpha then just scale and rotate as desired with the DVE.
  • William Busby
    May 2, 2010 at 7:05 pm
    You can do something like this believe it or not with BCC using the lens flare filter (without the flare) and just adjust the “rays” the way you want them
  • Matt Mullen
    May 3, 2010 at 4:37 pm
    You could also try using any of the BCC filters that might produce a desired result and use the pixel chooser within the filter to draw a custom spline around the eyes.
    A glow or lights filter might do it depending on what you are looking for.
