Activity Forums Apple Final Cut Pro Legacy Need to know the best way to covert PAL DV to NTSC DV
  • Need to know the best way to covert PAL DV to NTSC DV
    Posted by Benton on October 25, 2005 at 7:22 pm
    I work at a commercial/music video production company. I just received a drive that has about 50 PAL DV music videos on it. They are 720 x 576. What I need to do is convert them to NTSC DV and then compress them, with the end result being a DVD Studio Pro DVD. What is the best way to do the conversion? Should I use compressor? Should I render it out in FCP? I have a company that says they can lay it to Digi and then capture as NTSC. I am trying to keep the costs down on this, so I don’t want to do that unless it absolutely looks the best. Any suggestions?
    I have FCP 5.0, compressor 2.0 and DVD studio Pro 4. I also have Cleaner 6.0
    Benton
    Graeme Nattress replied 20 years, 10 months ago 2 Members · 5 Replies
  • Graeme Nattress
    October 25, 2005 at 8:04 pm
    I’ll give three answers:
    Best: Hardware tape to tape on a Snell & Wilcox Alchemist
    Cheapest: Use my standards conversion filter, at http://www.nattress.com – quality, as many on this forum will attest to, is great.
    Slowest: Use compressor, over 35 times slower than the cheapest option above.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Benton
    October 25, 2005 at 8:27 pm
    Does your filter look as good as compressor?
  • Graeme Nattress
    October 25, 2005 at 9:54 pm
    In all but the best and slowest mode, does my plugin produce better results than compressor. In compressor’s best mode, it’s slightly better at the expense of that enormous render time difference.
    Graeme
  • Benton
    October 26, 2005 at 4:19 pm
    Is it just advanced format conversions–DV NTSC?
  • Graeme Nattress
    October 26, 2005 at 7:48 pm
    Yes, but you’ve got to go into it and set everything to best or nearly best quality or the results don’t look too good, and it’s the high quality modes that make for the astronomic render times.
    Graeme
