Activity › Forums › Adobe Illustrator › Need to join 2 point in Illustrator cc
  • Need to join 2 point in Illustrator cc
    Posted by Rodeen Visser-ludick on August 24, 2014 at 10:33 am
    Hi Guys
    I am a newdbie in illustrator.
    I am doing a tutorial in Illustrator CC : (Create An Awesome Space Rocket Avatar in Illustrator)
    This is what I need to do:
    Now window-select the top points, hit Ctrl+J on your keyboard to activate the Join function. A dialog will appear, choose Corner. This way the rocket’s tip will be sharp. No respectable space rocket has a rounded tip!
    I can not activate the Join Function like in pics ? Mine automatically join with no Join Function box. Are there a setting I need to activate to get the Function box to show ?
    Please help.
    Jonathan Ziegler replied 12 years, 1 month ago 2 Members · 1 Reply
  • Jonathan Ziegler
    August 26, 2014 at 5:20 pm
    Might want to reset your dialog boxes. There might be an issue with the join and you may not be getting the warning. In General Preferences (Preferences: General?), click the button to reset all warning dialogs.
    Try doing this: create a line with the pen tool, switch to the arrow (V), select the line, go to edit > copy, then edit > “paste in front,” use the Direct Selection (A) arrow and DRAG to select one of the points (it will select both the top and bottom points. With them selected, hit join and you should see the dialog. If you do, then your other join operation may have a problem and you should reset the warnings.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
