Activity › Forums › Apple Final Cut Pro Legacy › Need to import Quicktime without render
  • Need to import Quicktime without render
    Posted by Kyler Boudreau on March 2, 2010 at 6:31 pm
    Hey forum – at a conference and need some help.
    Specs: MacPro Quad / Snow Leopard / Quicktime 10 / FCP7.
    Problem: need to correct a 10 frame audio drift without long render in FCP.
    Workflow:
    1) capturing footage from 2 cameras in Vidblaster (to edit on the fly). It only saves as WMV (or massive AVI). WMV file is 10mbps – pretty high rez.
    2) Purchased Flip4Mac and save the WMV file as a Quicktime. Import the Quicktime into FCP.
    3) Adjust audio and then try to send to Compressor. FCP wants to render. ARGH.
    4) Is there any way I can export the WMV from Quicktime in a certain codec so FCP doesn’t want to render? That would rock. These files are two hour session and I can’t afford the render time.
    Any advice most appreciated!
    _______________________
    kyler boudreau
    http://www.theatereleven.com
    ph.310.425.2231
    Kyler Boudreau replied 16 years, 7 months ago 3 Members · 3 Replies
  • John Fishback
    March 2, 2010 at 10:09 pm
    What kind of QT file are you making with Flip4Mac to bring into FCP? Dors your sequence setting match the QT file parameters? Mismatched file and seq settings are usual cause for unexpected rendering.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Michael Gissing
    March 2, 2010 at 10:17 pm
    Why does the audio drift and what needs to be rendered -video or audio? How are you fixing the drift?
    Perhaps if we solve the real issue the render issue will be moot.
  • Kyler Boudreau
    March 3, 2010 at 3:49 pm
    hey thanks – this has turned into a nightmare.
    how do you setup the sequence for that and what is the best codec for bringing into Final Cut? Yesterday I was encoding them as Prores 422 and three of them worked but still required rendering times of 20 minutes per hour of footage or so.
    The last three just crash Final Cut and Compressor when sending to compressor and/or fail in compressor.
    Dying here….thought Apple codecs would mean a smooth ride. Not so much.
    kyler boudreau
    ph.310.425.2231
