Activity › Forums › Maxon Cinema 4D › Need to have x-particles disappear when hitting specific objects
Posted by Jon Simpson on June 8, 2015 at 1:56 pmThe subject line says it all.
Adam Trachtenberg replied 11 years, 3 months ago 3 Members · 6 Replies -
Jordan Quackenbush
June 8, 2015 at 3:33 pmAdd the xpKill modifer, set it to Independent on the first Object Properties “Mode,” and “Objects” on the second “Mode.” Put the objects in the Objects box.
Jordan Q
If I’m posting a question, it means I’ve Googled it for far too long and couldn’t find a solution/answer. -
Jon Simpson
June 8, 2015 at 4:00 pm -
Jordan Quackenbush
June 8, 2015 at 4:05 pm -
Jordan Quackenbush
June 8, 2015 at 4:31 pmThen I don’t know – my next steps would be checking the manual for how to enable that objects box, googling around, or…upgrading to 3. It’s pretty awesome. You can try the X-Partlcles forum, if you haven’t already.
Jordan Q
Adam Trachtenberg
June 8, 2015 at 5:52 pmSet the Mode of the kill modifier to Object and then drag your object into the objects box.
