Activity Forums Adobe After Effects Need to generate random numbers like in an iP address
  • Need to generate random numbers like in an iP address
    Posted by Insaf Nias on February 19, 2020 at 7:12 am
    Hi Guys,
    I am literally tearing my head off ☹
    I need to create an effect of a screen filled with ip addresses which keeps on changing randomly
    Example – 192. 125.01.02
    I have no idea on how to get the 4 punctuation.
    Appreciate the help
    Thank you,
    Insaf Nias
    Insaf Nias replied 6 years, 7 months ago 3 Members · 4 Replies
  • Eric Santiago
    February 19, 2020 at 4:11 pm
    I know there is a script for that but I’ve had to do it using multiple comps to create that sequence.
  • Insaf Nias
    February 19, 2020 at 7:05 pm
    Hi Eric,
    But how were you able to move the position of the numbers when the it changes from 2 digits to 3, because the position of the punctuation changes as per the number of digits.
    There are scripts that work like a charm, but it generates only one punctuation (ex. 192.52)
    I am so damn lost ☹ been struggling for days with this thing!
    Regards
    Insaf Nias
  • Greg Gesch
    February 20, 2020 at 1:04 am
    Hi Insaf. I don’t know what I’m talking about but:
    “There are scripts that work like a charm, but it generates only one punctuation (ex. 192.52)”
    Is it possible to put two of the numbers side by side ie. 192.52, then a full stop and then add another iteration on the same line?
  • Insaf Nias
    February 20, 2020 at 6:56 am
    Hi Greg,
    The issue with that method is that the position of the punctuation changes according to the number.
    I used the following script; but it give me only one punctuation point, i need 3 in total (Ex – 192.168.25.01)
    frames = 10; // frames to hold each random number
    seed = Math.floor((time – inPoint)/framesToTime(frames));
    seedRandom(seed,true);
    random(300).toFixed(2)
