Activity › Forums › Apple Final Cut Pro Legacy › Need to extract extras
  • Neil Patience
    March 19, 2012 at 6:24 pm
    Inside the TS folder there should be a VOB file for the extras content.
    You would have to do a bit of trial and error to see which one to open but you should find it.
    best wishes
    Neil
    http://www.patience.tv
  • Juan Manuel
    March 19, 2012 at 6:58 pm
    If you have a PC around, or Windows running in your mac, you can use an old freeware called DVD Decrypter to extract just the extras
  • Jim Makichuk
    March 19, 2012 at 10:16 pm
    Thanks all very simple too. One other thing, I’m going to edit a mix of HD 1080i and 4:3 DVD video and b&w stills. Not sure format should I use for final product to dvd? Seems like 16:9 would be one choice?
  • Neil Patience
    March 19, 2012 at 11:32 pm
    Since you are questioning 16×9 or not for your DVD I assume you are considering editing this propsal film in Standard def.
    That actually makes a lot of sense especially if viewing will be on a DVD and as the 4×3 DVD source will suffer like hell getting to HD only to be resized back to SD for a DVD looking much worse for the journey.
    I would probably edit in SD 16×9 and then either pillarbox the 4×3 or zoom in to it if it looks like it can handle it quality wise.
    Plug-ins like Neat Video could help you de-noise the DVD footage.
    Hopefully you will get a commision and then go HD and hopefully get better source for your archive.
    best wishes
    Neil
