Activity Forums Avid Media Composer Need to export Prores444 UHD wt 8 audio channels
  • Need to export Prores444 UHD wt 8 audio channels
    Posted by Chris Coote on May 19, 2015 at 3:58 pm
    Hi
    I am working at 3840×2160 in Avid. I need to deliver Prores444 with 8 discreet audio channels.
    As far as I know, I can’t do this directly out of Avid? In testing, my workaround is export same as source
    to DNXHRX with 8 discreet channels and then open the file in QT – re-export to Prores444.
    Is this the best/only way to do this?
    Chris
    John Pale replied 11 years, 3 months ago 3 Members · 3 Replies
  • Massimo Alberto croce
    May 19, 2015 at 8:21 pm
    Why don’t do directly from avid?
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Chris Coote
    May 19, 2015 at 8:31 pm
    Direct out is greyed out in the audio settings unless you do a same as source or reference movie.
    You can’t do a mixdown to prores in the avid in UHD resolution, only in HD.
    Unless there is some other way I am missing?…
  • John Pale
    May 23, 2015 at 3:25 pm
    Not in front of a system to test, but if you switch the color space to RGB, does ProRes become a media creation option in a UHD project?
