Activity › Forums › Apple Final Cut Pro Legacy › Need to export JPEG2000 in MXF wrapper
Posted by Cade White on August 2, 2012 at 10:36 pmI need to export a 30 minute show as a JPEG2000 in a MXF wrapper. We on the latest Mac Pros and have access to FCP7 or FCPX. We could also use Premiere Pro CS6 if needed.
Any ideas?
Kai Von garnier replied 13 years, 2 months ago 6 Members · 8 Replies -
Cade White
August 3, 2012 at 3:44 amI have learned that the station where this show will run is using a Maxx 1200 HD system.
Shane Ross
August 3, 2012 at 5:15 amWell, apparently it isn’t easy…
https://community.avid.com/forums/p/60111/336750.aspx
https://forums.creativecow.net/thread/20/865962
Still unsure how to do it. Wonder why it is so hard to do.
Ahhh…
https://www.digital-rapids.com/Products/IndividualProducts/Stream%20Software/FormatOptions.aspx
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Cade White
August 3, 2012 at 5:45 amThanks for the links. Searching this and other forums I’ve found several threads addressing this problem….none with a real clear solution.
The Digital Rapids products look quite capable but it appears they’re all windows only. Unfortunately, we are Mac-only and adding new hardware isn’t an option.
And, to complicate this even more, the solution we end up with needs to support closed captioning.
Frustrating…
Rafael Amador
August 3, 2012 at 9:51 pmHave a look to those link:
https://hamburgpromedia.com/
https://www.reduser.net/forum/archive/index.php/t-44480.html
rafael -
Joseph Owens
August 7, 2012 at 8:40 pmRafael’s second URL will probably be more useful, as it sounds like you’re being asked to make a DCP.
Getting trendy.jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
Cade White
August 7, 2012 at 9:26 pmHas anyone tried the MXF export suite from Hamburg Media? https://home.mxf4mac.com/shop.html
Kim Rowley
March 27, 2013 at 8:23 amHi Cade,
I have the exact same need (Export a Jpeg2000 file with MXF wrapping). Have you made any decisions since your last post? I have been using the MXF4Mac plugins from Hamburg Media for the past few years (exporting in IMX50) with no apparent issues. Our shop is starting to digitize legacy DigiBeta tapes using the Digital Rapids encoder but I need to know how to do the same with new edited programs from FCP.
How are you fairing?
Kim2x 2.4 GHz Quad-Core Intel Xeon 12GB RAM, ATI Radeon HD 5770, Xserve RAID, AJA IO, 2 Cinema Display, FCP Studio 3 (7.0.3), OS X10.6.5
Kai Von garnier
July 16, 2013 at 2:29 pmHello Kim,
since e do have a JPEG2000 Importer, we are working an Exporter as well.
I hope, we can release this year
Best regards
Kai
