Activity Forums Adobe Premiere Pro Need to export 29.97 w/ 23.98 footage
  • Need to export 29.97 w/ 23.98 footage
    Posted by Heather Brown on May 8, 2015 at 12:35 am
    Playback system requirements need my videos to be 29.97. They are shot and edited at 23.98fps.
    Is it better to:
    1. Cut + paste content into a 29.97 sequence before export
    2. Keep in 23.98 and just export 29.97
    3. Either/or..quality is the same.
    Ideally, I would like to do #2, but don’t want to sacrifice quality.
    TIA,
    Heather
    Jason Guerra replied 11 years, 3 months ago 2 Members · 1 Reply
  • Jason Guerra
    May 8, 2015 at 3:59 pm
    I would also go with option 2. There shouldn’t be a significant difference in final export with option 1 vs 2, but their will be a huge difference in editing. Option 1 will mean converting the framerate on the fly with Mercury Playback, which will slow down performance. Probably not much, but still. Also, I have noticed a significant difference in the way framerate conversion look in timeline vs final export, so with option 1, if you see a weird artifact from the conversion on your timeline, it won’t necessarily export that way. Option 2 avoid all of that.
    If you want to be 100% sure about quality, take a small, 30 second to 1 minute, clip and test it with both options. That way you get to see with your own eyes and will know make sure you are satisfied with the results.
