Activity Forums Adobe Photoshop Need to edit locked photo
  • Need to edit locked photo
    Posted by Anandabrata Ghosh on May 24, 2008 at 10:03 am
    I am using photoshop cs2. I intend to edit the photo.
    1) So I open photoshop and then say file–>open–><>. The image is a gif file.
    2) But I see that everything is disabled. The layer, filters, etc. The only options available are the tools like crop, select,etc and canvas size, image size etc.
    3) I am not being able to do anything with the image. I am not even able create a new layer since the layer menu is disabled.
    4) I have also tried to save the file as a tiff and then make changes but the result is the same as above.
    Any help how can I unlock the layer/image will be of help.
    Anand
    Joe Hayden replied 17 years, 11 months ago 4 Members · 4 Replies
  • Zak Ezzati
    May 25, 2008 at 1:41 am
    If you are Mac OS then in the finder select the file and do > FILE > GET INFO and change ownership & permissions and details.
  • Anandabrata Ghosh
    May 25, 2008 at 6:24 am
    I am on windows and I don’t think it is a permission issue. Also the file is not read only.
  • Ekim Wahs
    May 27, 2008 at 7:47 pm
    Sounds like you opened a index color mode image. Try converting to RGB.
    Mike Shaw
    Photoshop QE
  • Joe Hayden
    June 2, 2008 at 6:00 pm
    with gifs I often will select all >copy and paste to a new document.
    L.O.A.
