Activity Forums Adobe After Effects need to create a light trail from a light globe as it swings
  • need to create a light trail from a light globe as it swings
    Posted by Chris Huggett on July 28, 2005 at 1:55 am
    hey guys
    we have shot a scene of a lit lightglobe swinging in a darkened room. I have been asked to create more of a light trail as it swings past the camera.
    the final grade will be black and white, so matching the colour isn’t a problem.
    any ideas. we have trapcodes particular if it helps.
    thanks
    Chris
    Filip Vandueren replied 21 years, 1 month ago 3 Members · 2 Replies
  • John Dickinson
    July 28, 2005 at 3:03 am
    Hi Chris,
    Take a look in the Trapcode Gallery (https://www.trapcode.com/gallery.html). There’s a clip by Jason Koxvold that may give you some ideas. You could also try the Time effects such as Echo, Wide Time etc. That may be a better way to go…
    cheers,
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Filip Vandueren
    July 31, 2005 at 12:39 am
    If using echo doesn’t work out for you.
    Try doing a motion track on the light-bulb, and use the resulting position as an effect-point for the Write-On effect.
    Combine that with some glow and let it fade away in time.
