Activity Forums Adobe After Effects need to create a goopy chocolate wipe
  • need to create a goopy chocolate wipe
    Posted by Heather Crank on February 29, 2012 at 11:28 pm
    I need to create some liquid chocolate that wipes across the page in a drippy goopy way…think oozzzing chocolate…has anyone ever done this? Did you use ae and a plug in or did you use a 3-d program?
    Right now I have something using fractal noise and masks, but it looks more that a satiny fabric instead of goopy. Anyone have any suggestions?
    H
    Heather Crank replied 14 years, 6 months ago 4 Members · 6 Replies
  • Erik Waluska
    March 1, 2012 at 1:20 am
    Here’s a tutorial about making the fractal noise look like liquid that might help.
  • Kevin Camp
    March 1, 2012 at 5:54 am
    Take a look at cc mr mercury or cc glue gun applied to a chocolate brown layer.
    Also a drippy mask with cc glass may start getting close. You may need to apply cc glass as an adjustment layer, I’m not sure it sees the mask as a layer’s alpha if applied directly.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • John Cuevas
    March 1, 2012 at 3:28 pm
    You might want to take a look at this tutorial using Freeform to create a waterbox, you probably could adapt it to your needs:
    https://ae.tutsplus.com/tutorials/motion-graphics/create-a-water-box-using-shapeshifterae/
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Heather Crank
    March 1, 2012 at 4:05 pm
    Thanks…that’s what I’ve got going now, but need it to be more gooey….I’ll keep trying!
  • Heather Crank
    Thanks Kevin, great suggestions, I’ll give them a shot!
  • Heather Crank
    March 1, 2012 at 4:06 pm
    ooohh, thanks, this may do the trick!
