Activity Forums Adobe After Effects Expressions Need to control two key frames with expression
  • Need to control two key frames with expression
    Posted by Anoop Kumar on May 29, 2015 at 6:22 am
    Hi CC,
    Here is my first post!!!
    I am doing a shape layer (trim) animation. The keyframes are set to “end” value from 0–100 (time 0–2 Seconds). Now I need to control this speed with a controller, I think I can use sliderControl for this. Any help to do this with expressions will be great.
    Mark Borgions replied 11 years, 3 months ago 2 Members · 3 Replies
  • Mark Borgions
    June 8, 2015 at 10:24 am
    There might be a better way, but I do this kind of thing with a marker (on layer or comp level)
    Then have a slider control the time offset in seconds.
    Hope this helps.
    Mark
    endFrame = thisLayer.marker.key("MARKERNAME").time ;
    timeOffset = pickwhip-the-slidercontrol ;
    linear (t=time, endFrame-timeOffset, endFrame, 0,100)
  • Anoop Kumar
    June 9, 2015 at 10:03 am
    Thanks so much Mark!!! Very very helpful!! I’ve got what I needed. But I’ve made some slight edits to the expression. Below is the one which I’ve used. Thanks so much!!!!
    startFrame = thisLayer.marker.key("1").time ;
    timeOffset = -1*comp("Contorls").layer("Contorls").effect("Animation Offest (Speed)")(1);
    ease,ease (t=time, startFrame-timeOffset, startFrame, 0,100)
    Anoop
  • Mark Borgions
    June 9, 2015 at 10:05 am
    You’re welcome
    M
