Activity Forums Apple Final Cut Pro Legacy Need to changed the audio tracks
  • Need to changed the audio tracks
    Posted by Tony Kloiber on March 8, 2007 at 9:44 pm
    I need to changed the audio tracks that were captured on several clips (these clips are also used in multiclips and have been used heavily in a number of sequences).
    Ch.1 was captured originally and it should of been Ch. 2, would someone like to run through the steps to fix this.
    Thank You,
    TonyTony
    Tony Kloiber replied 19 years, 6 months ago 2 Members · 2 Replies
  • Chris Tompkins
    March 8, 2007 at 9:53 pm
    Well, you could make all the media “off-line” and then choose to batch capture and change the settings or just change the cable on the mixer, etc.
  • Tony Kloiber
    March 9, 2007 at 2:28 pm
    Well I could make the work around off the swap at the mixer but this can be a problem in the future if this ever gets recaptured (you know like years from now some wants to do a “simple ” re-edit).
    making it off line and changing the settings is what I would do but I’m concerned about the multiclip part of it. I have all this stuff cut using multiclips with audio on ch.1 now it will be on ch.2.
    Guess I have to try it and see, worst case I go back to cable swaping.
    TonyTony
