Activity › Forums › DaVinci Resolve › Need to buy a Resolve Computer for Dailies
Posted by Eric Chase on October 24, 2013 at 3:37 pmWhat do you guys think I should buy?
I’m just looking a computer to render out dailies and some light editing. Nothing too heavyA: 2008 8 Core Mac Pro
B: 4 core 2.3ghz i7 Mac Mini
C: 21″ imac 4core i5 (current model)
D: 27-inch iMac 3.4GHz quad-core Intel Core i7
Thanks!!
Eric Hansen replied 12 years, 10 months ago 6 Members · 7 Replies -
Chris Kenny
October 24, 2013 at 9:59 pmEither the Mac Pro with an aftermarket graphics card or the 27″ iMac with the GeForce GTX 780M 4GB GDDR5 upgrade. The latter is what I’d do if I had to buy right now. (Otherwise I’d wait for the new Mac Pro.)
The other systems you mention have Intel GPUs which Resolve can’t use. Mavericks adds OpenCL support for Intel GPUs, which might make them usable eventually (they still don’t work at present, apparently), but I wouldn’t bet on good performance from them.
Digital Workflow/Colorist, Nice Dissolve.You should follow me on Twitter here. Or read our blog.
Paul Provost
October 25, 2013 at 5:11 amCurrent iMac
That Mac Pro is too oldhttp://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
Twitter 4kfinish -
Kevin Cannon
October 25, 2013 at 2:59 pmAgree with Paul – even if you find GPU and CPU performance is acceptable on the old mac pro, you’ll have to use PCI slots for e-sata and USB3, and really having no option for thunderbolt drives – we’re starting to see a majority of USB3/thunderbolt only drives come in. An iMac (plus the cheap TB>Firewire800 and USB3>e-sata adapters) should give you all the fast connections you need. Same should be true of the new mac pro.
Cheers,
KC
Eric Chase
October 25, 2013 at 3:42 pmThanks for your responses. For a rebuttal, this is dailies only, so a cuda GFX card isn’t necessary (as my understanding.)
I have an esata card for the old mac pro option. And If I get an iMac, it is 250% more for a newer one than an old mac pro.
I see you’re point.
If I bought the new mac book pro, then I guess its a no brainer, huh?
Paul Provost
October 25, 2013 at 4:21 pmRed already has open cl debayer and going cuda soon for multiple gpu r3d transcode. You’re going to want that. Bus speed on that old Mac Pro is slowwww. Don’t get that.
There’s a good thread on a reasonable hackintosh render box over on liftgammagain.com by Jason Myres
That might actually be your best optionhttp://www.4Kfinish.com | owner-colorist | Hollywood, CA
Twitter 4kfinish -
Gerry Curtis
October 25, 2013 at 8:31 pmIt’s hard to answer which computer without knowing the prices and what kind of footage you’re working with but if the MacPro is a good price relative to the others I wouldn’t dismiss that as an option.
You can RAID 0 the non OS internal drives, which are relatively cheap and update the GPU if need be and it can still be pretty fast machine. It’s all about finding the best price vs performance.Cheers,
Gerry
http://www.digitalkilnstudios.com
http://www.savasanafilm.com -
Eric Hansen
October 26, 2013 at 4:28 pmthe 2009 or 2010 Mac Pro has a significantly faster bus and much cheaper RAM than the 2008 for very little extra money.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
https://www.erichansen.tv
