need to be able to rotate individual keyframes/ cloning areas CS4
I am using a position expression for a clone which is pick whipped back to the feature center of a track point. I need to be able to rotate individual frames of the clone. Although I can rotate the clone in the clone settings, this affects the entire video and I need to be able to rotate specific frames only. I can move the feature center of each track point frame, but no rotation option is there that I can see.
Any help would be appreciated.
thanks,
Jon
