Activity Forums Adobe Premiere Pro Need to add to begining
  • Need to add to begining
    Posted by Deepmine on December 7, 2007 at 3:24 am
    Sorry for the basic question, but I’m rusty on PPro 1.5 and can’t remember how to move my entire sequence intact forward on the timeline…
    I need to add to add about 10 seconds to the beginning. Can’t seem to find the info in the help section.
    Thanks, Deep
    Deepmine replied 18 years, 9 months ago 2 Members · 2 Replies
  • Heath Firestone
    December 7, 2007 at 5:51 am
    Try pressing M, which will activate the track select tool. Hold down shift, which will select all tracks, represented by two arrows as apposed to the one when in single track select mode. Click and drag the first clip you want shifted, while holding down on the shift button, and drag to where you want it. If you want to go directly to 5 seconds, type in 500 enter which will move your cursor to the 5 second mark. If you have snap on, you can drag it so it snaps to that point.
    Hope this helps.
    Heath
  • Deepmine
    December 10, 2007 at 1:17 am
    Thanks, that did the trick
    Deep
