Need To Add A 3rd Monitor! ..Any Suggestions, How & What I Need To Add Up In My System?
Hello there you cows..! 🙂
I need your help…
I have a PPCS5.5 system with 2 PC monitors (DVI) on a GTX480 GPU.
I need to add up a 3rd monitor (27″ HDTV), mostly to be able to check how the final result will look out on a big TV, but also to broaden my desktop’s real estate..
I have an older GPU, lying arround and was wondering if it would work, giving me a third monitor output, if I plugged it on my MOBO, while keep using my GTX480 as my primary GPU with full advantage of all CUDA cores with the MPE.
The older GPU is an NVIDIA GeForce 7800… I have a concern if the installed drivers of the GTX480 would conflict with this older GPU
and that if I install it’s own drivers, that the newer & older drivers will conflict with each other… (I think it’s not even possible, to install both drivers for both GPUs. I remember when I purchased the GTX480, the setup wizard asked to uninstall the older drivers, before completing with installation)
Any suggestions here please.. I would like to here about similar experiences before begin the testing phase (which is not always safe)..Thank you in advance.
