Activity › Forums › Adobe Premiere Pro › Need the smallest file possible for exporting
Posted by Forrest Mcbride on June 13, 2017 at 7:12 pmSo I made a series of 2-minute clips for the company I’m working for.
However, the 150mb files are too big for them. At the moment I’m exporting 1080p in H.264.
They want the files to be around 30mb, is this possible without losing a lot of quality?
Chris Wright replied 9 years, 3 months ago 5 Members · 4 Replies -
Tero Ahlfors
June 14, 2017 at 3:55 am[Forrest McBride] “They want the files to be around 30mb, is this possible without losing a lot of quality?
“You can set the bitrate so that the file will be under 30 megs. That will probably look bad because it’s not a lot of data for a 2 minute video.
Michael Krueger
June 14, 2017 at 12:37 pmSet the video target bitrate to 2 Mbit, video maximum to 3 Mbit and don´t forget to also lower the audio bitrate to 96 kbit.
Depending on the source material (movement, noise, lighting) you will lose a lot of quality but there’s no way around it when size matters. -
Jeff Pulera
June 14, 2017 at 1:49 pmIt is true that the only way to make a file smaller is to lower the bitrate. However, using a smaller frame size will get you more quality at that lower bitrate, since there is less video to compress.
So for instance, at a given (low) bitrate, a 720p video should in theory look better than a 1080p video at that same bitrate, since far less pixels needed to be compressed. The question is then, how will the video be used/viewed? 720p is still HD video and would seem to be a better choice in this situation. Or how about 360p, which is 640×360?
Not knowing the content of the video or intended viewing methods, hard to say, but if for instance this is a talking head video, 360p could look just fine!
Jeff Pulera
Safe Harbor Computers -
Chris Wright
June 15, 2017 at 6:34 amIf you choose aac audio, you can go 64kbps that will sound like 128.
Half your resolution.
Also framerate can be lowered with optical flow.
Do a heavy denoise first before compression. -
Veronika Bolotina
January 12, 2022 at 12:13 pmWhat if I am choosing 128k, but in the end it always renders out with a bit fewer kbps. Like 126k.
What do I have to do to get the exact 128k?
Thank you
