Activity Forums Adobe After Effects need suggestion
  • need suggestion
    Posted by Anand Rajput on January 4, 2016 at 9:16 am
    Hi
    Happy New Year to all
    i am stuck in one job and i have no clue how to that
    link of the similar is attached i want text part only (wave text part)
    if any one of you guys can suggest something it will be a great help
    thanks in advance
    https://vimeo.com/26328656
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Kevin Welchman replied 10 years, 8 months ago 4 Members · 4 Replies
  • Joseph W. bourke
    January 4, 2016 at 3:08 pm
    In my opinion, this effect was done in a 3D application (I use 3DS Max, so the link below is a search based on Max:
    https://www.google.com/search?q=3d+wave#q=3d+wave+3ds+max
    The text could be done in After Effects, then saved as a .mov file with an alpha channel, then used as the texture map in Max (or other 3D application).
    This is how I would do it. There are other ways, using other applications – I’m sure it could be done in Cinema 4D as well. The most difficult part is rigging the breaking wave shown at the beginning, but there are some free rigs out there, at least for Max. Here’s a tutorial on rigging waves in Max:
    https://www.evermotion.org/tutorials/show/8313/3ds-max-rigging-waves
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Anand Rajput
    January 4, 2016 at 5:32 pm
    Thanks joseph for replying.
    its a great help
    But as in begning the text overlapping and text reacting as repulsive wave how can we that
    If u can help in that also it will be a great help
    Thanks once again for reply
    Thanks and regards
  • Chris Evans
    January 4, 2016 at 6:01 pm
    You could animate one word in the wave motion. Put it in 3d space and have it go in a circle while scaling up then down. Duplicate it a bunch and put them all in a line, duplicate all those and offset their position and timing so that they form the wave. You couldn’t create a braking wave like this, but a simple wave would be fairly easy.
  • Kevin Welchman
    January 4, 2016 at 8:03 pm
    you could do this in c4d very easily
    Animate the txt however you want; you could even make it in AE and then export a video with transparent background. Go into C4D, create a plane, then use you video as a texture. Then put your plane(with text video as texture) into a cloner. then use a Plane effector with the falloff shape as: box. You can set up you Plane effector to change the direction, size, spacing of the clones.
    OR
    And this may be easier. Export your text as png’s with transparent background, make a cloner and put a bunch of planes in it. Create a multi-shader texure. You do this by adding a Random Effector to the cloner; turn everything off on the Random effector but have Color Mode: On. Once you do this, all you have to do is animate the Seed and it will randomly cycle through the textures on your multi-shader
    I know that may be a lot but if you google anything you dont understand, there should be a quick tutorial on it.
