Activity Forums VEGAS Pro Need someone to create Vegas projects
  • Need someone to create Vegas projects
    Posted by Derek Stewardson on April 10, 2008 at 8:37 pm
    I’m backed up with other projects and need someone versed in Vegas to created a bunch of Vegas projects for me. I can render them. They are based on PowerPoint presentations. You can view a completed one at https://www.advanceddm.com/ssi_training/sub-surface.html .
    There’s 8 more videos to be put together which vary in length. I will supply:
    – the original PowerPoint presentations
    – voice-over files
    – that contain all of the textural content from the PowerPoint presentations
    – I have pulled all of the original images from the original PowerPoint slides and resized them as needed and stored them in the individual folders.
    – I have a basic Vegas project for each PP slideshow that I placed all of the audio files and placed markers in each project that correspond to each slide position.
    – I have also imported the images needed for each Vegas project.
    There are the basic text graphics (and open and close segments) for each project in each Vegas VEG file that can be cloned and edited as needed. I was also using some very simple masking to reveal each line of text as needed.
    Give me an approximate cost (basically tell me what you would charge to put together the one above) and turn-around time. These need to be done ASAP!! I can pay via PayPal, company check or whatever else once completed. There will be changes to each after the initial ones are done which would, of course, be on top of the cost to create the original Vegas projects.
    You can check out my feedback on scriptlance.com (deuce) and ebay (deuce251) if you’re concerned about my integrity. 🙂
    Derek
    Kyle Koch replied 18 years, 5 months ago 4 Members · 3 Replies
  • Adam Rose esq.
    April 11, 2008 at 7:57 am
    you COULD use Camtasia or similar to record the powerpoint playback directly on your machine while the audio plays on another device (for sync)
    This would give you each project as an AVI in the time it takes to play it through once…
    my 2c
  • Paul Campbell
    April 11, 2008 at 1:17 pm
    Hi Derek,
    I’d be more than happy to help you out with this! I’m an experienced professional editor and sound guy, so you’re assured of top notch results.
    I’m based in Cape Town, SA, so media size and download management will have to be optimized.
    I charge USD350 a day for my services. Please get in touch to
    discuss this further.
    Regards,
    Paul Campbell
  • Kyle Koch
    April 16, 2008 at 7:28 am
    Hi Derek,
    Happy to help.
    What are the length of the projects and what are the delivery specs.
    You can look at my work at http://www.cinergy-entertainment.com. Check out the editing projects, many of which were done in vegas.
    There is always a point where one needs to reinterpret a clients message with regard to moving a message from one medium to another. You will see from my volume and depth of work, that I can do a great job.
    Either give me a call at 604-618-5953 or email me at kyle@cinergy-entertainment.com and we can discuss how to get the best imaging for the best cost/time efficiency.
    I may be able to help you automate your workflow so you can do this yourself.
    Cheers,
    Kyle W. Koch
    Cinergy Entertainment Inc.
    (604) 618-5953
