Activity Forums Adobe Audition need some voices
  • need some voices
    Posted by Sam Wiley on June 23, 2007 at 7:25 am
    i need to know how to make a combine soldier (from half-life 2) voice
    a dalek voice, and a menacing robot voice. any help would be appreciated.
    Nick Wheeler replied 14 years, 11 months ago 4 Members · 4 Replies
  • Ptrani
    June 25, 2007 at 5:49 am
    When you say merge, you just want to play one after the other, right? You can use different tracks in Audition and have each one in it’s own track. Or you can use Soundbooth and do the same thing. The beta is available on labs.adobe.com It’s free and easy to use!
    Paul Trani | Adobe Certified Expert
  • Darren Edwards
    June 25, 2007 at 11:05 am
    Dalek – https://en.wikipedia.org/wiki/Dalek
    A third of the way down the screen, the modulation,
    EQ, and sine wave tools which is mentioned in the
    ‘Voices’ paragraph, can all be found within Audition.
    You’ll probably need all 3 effects to pull it off
    authentically, so consider it a good self-tutorial.
    Robot Voice – Effects/Delay Effects/Echo/Robotic
    This is will give you something metallic-sounding.
    A start, at least.
    Effects/Time_Pitch/Pitchbender/Up a Whole Step
    Effects/Delay Effects/Sweeping Phaser
    Effects/Filters/Dynamic EQ
    – are just three of the ways to ‘alienify’ things.
    Combine – Effects/Filters/FFT Filter/Telephone Filter
    (or Voicemail)
    These are walkie-talkie-sounding filters. Have fun
    playing around with them.
    Darren.
    myspace.com/xgfmedia
  • Nick Wheeler
    March 8, 2011 at 2:23 am
    XGFMedia: Really you don’t even need the effects like that for the combine, for me it’s just a hassle and the results are sometimes limited. You can use the View>Spectral Frequency Display select the middle (frequency selection tool “F”)to find the area you are sure you want to keep, then delete the top and bottom of the selection until the desired radio/phone voice is acquired.
  • Nick Wheeler
    October 8, 2011 at 5:37 pm
    Sorry I don’t know why I forgot to add lowering the pitch apart from tempo. Then play with a few preset effects. I just got a perfect sounding combine. If you want I’ll make a quick tutorial.
