Activity Forums Avid Media Composer Need some Tech help with External Hard Drive
  • Need some Tech help with External Hard Drive
    Posted by Jeff Gish on October 26, 2005 at 10:05 pm
    Not sure if this is the right forum, but let me present my situation. I have a Maxtor External Hard Drive (250Gb) that I bought to archive some stuff. Here is my problem….I want to be able to use it on our Mac Based Avid and iMac and also need to use it on the NT based Quantel Eq system. How do I format the drive so that I can read/write both the the PC and mac world?
    R Lague replied 20 years, 10 months ago 4 Members · 4 Replies
  • Bob Sykes
    October 26, 2005 at 10:07 pm
    Fat 32
  • Jeff Gish
    October 26, 2005 at 10:14 pm
    I am not a tech head when it comes to formatting stuff, can you explain what and how I do this Fat32? And are their limitations? I have a 250gb drive.
  • Michael Mcintyre
    October 27, 2005 at 10:56 pm
    I’m no techie either but FAT 32 is a disk formatting thingie. That’s it. Whatever it is, it makes both makes Mac’s and PC’s happy and they both can ‘speak the FAT32 language’. Using Disk Management on PC (that’s how I did it), or something else on the Mac you go to format the drive when you’re good and ready and it’ll ask what file format you want it in. Very easy. Hell, I did it and I don’t even know what I’m talking about.
    If you format your external drive as FAT32, it should work. The only problem might be that you mentioned it’s 250 gig’s. Someone I’m sure will correct me on this or have more techie than I info but FAT32 doesn’t like drive partitions over a certain limit. So – off to Disk Management and / or Disk Utility with ye!
    So, if all my information isn’t perfect, someone somewhere can remind me of my limitations and correct me on the intricacies and history of the FAT32 file structure. Your drive should work eventually. And we’ll all live on to healthy and productive lives. That is except for the guy waiting to correct me…….
  • R Lague
    October 28, 2005 at 12:16 am
    the Maxtor comes with FAT 32 on it from the factory. So you have nothing to worry about or anhything to change.
