Activity › Forums › Apple Final Cut Pro Legacy › need some help
  • Posted by Nectarios Leonidas on November 15, 2005 at 9:37 pm
    Here goes.
    I’m cutting my first film based project. I read cinema tools manual and all additional info I could find on the net, but still need some help.
    When I do the reverse pull down. I tried to do a test for all settings to figure out which is the best. from F1 one only / F2 two only and select either a / b / c / d.. and so on. While reading some posts here and another site, they stated A B C D frames after the pull down the letters should cleared and not jerky, right?
    Also, what settings do I have to have the time line besides 23.98fps. Because when I take some of the footage into it, I have to render them to view?
    And last, I think I did something majority stupid. I did a reverse pull down on the master QuickTime file. is there a way do undo this?
    All help and advise is greatly appreciated.
    nl
    nectarios leonidas
    film | video | web
    http://www.flippant.net
    Jerry Hofmann replied 20 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 16, 2005 at 3:05 pm
    If you replaced the original file with the processed file, there’s no going back other than to recapture I’d think.
    What do you intend to deliver? a cut list to cut the negative with? or s is delivery going to be video?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
