Activity Forums Adobe Illustrator Need some advice in illustrator
  • Vincent Rosati
    April 1, 2012 at 8:22 pm
    Looks like that graphic was probably created in a 3D app. Naturally, you could make something like that by drawing a bunch of triangles, and position all of the points with View / Snap to Point enabled.
    As far as coloring it, you’d just have to do it piece by piece.
    There are a number approaches you could take.
    One might be to simply set color and transparency for each piece.
    Another might take this a step further by duplicating the finished triangle components and Pathfinder / Unite. Then place the united component in a layer below the main component. Then you could fill the united component with an interesting gradient or something. Then for the main triangles you could experiment with different transparency modes.
    3932_triangles.ai.zip
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Scott Roberts
    April 5, 2012 at 5:07 am
    I’d make filled triangle shapes, overlayed over each other and transparency – either opacity variations or blending modes.
    LittleBlackBird.net
