Activity Forums Broadcasting Need solution to access MP3 etc from storage
  • Need solution to access MP3 etc from storage
    Posted by Azhar Munir on March 2, 2009 at 7:03 am
    I need to prepare a solution to stream MP3 & MPEG formats to LCD screen.
    I have one 42U cabinet to have a Dell or HP 10TB storage. I need to connect two PC’s via SCSI to storage. Each PC to have DVI output. DVI output will go into a HDMI Matrix 8×8 with Octava Ethernet Transceiver which will be connected to LCD’s, AMX controller system will be used to select respective LCD to display one of the PC.
    Will this method work out to watch or play from the server on selected LCD?
    Bluetooth Keyboard & Mouse will not be able to control the selected PC. I have Access Points. How can I access PC without using any wired keyboard & mouse?
    If above is not possible then what is the best solution, as AMX & Matrix etc are all setup and available.
    Thank you.
    Azhar Munir,
    Information Network
    +965 97218111
    Azhar Munir replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
