Activity › Forums › Adobe Premiere Pro › Need solution for export smooth VCD
Posted by Binh Le on May 24, 2007 at 8:44 amHi,
I have problem to export to VCD from DV project: moved object in video is twitch. I know that Video in DV mode is used field base but VCD is not. Any one have solution for this problem.
I tried with some encoder software but the same.Thanks a lot.
Binh Le replied 19 years, 3 months ago 3 Members · 6 Replies -
Mike Velte
May 24, 2007 at 9:17 amA VCD is a very low bitrate (1 mbps) format with very poor resolution (352×240). I cant imagine a need to use this legacy format.
Binh Le
May 25, 2007 at 1:09 amI live in Vietnam, people is poor so VCD player is more popular than DVD player, our customer need to trasfer video to VCD that why I need its.
Perry Cheng
May 25, 2007 at 2:21 pmWhen you export to .avi, and view it in your monitor, do you see twitch? Do you choose export “always de-interlaced?” I have luck with TMPGENC to export to VCD with pretty decent quality (regular TV of course).
Perry
Binh Le
May 26, 2007 at 8:49 amThe .AVI file export from timeline is OK (view on TV) but then I use Canopus Procoder and TMPGENC convert file .avi to MPEG1-VCD then it is twitch in regular TV.
Could you show me options in TMPGENC that you set for VCD.
Thanks you very much.
Binh Le -
Perry Cheng
May 26, 2007 at 11:25 amHave you try always deinterlaced? BTW, where is the twitching? Edges? or the entire screen? Could it be you PAL vs NTSC issue also? Is it happening with all VCD output or just this one?
Perry
Binh Le
May 26, 2007 at 1:20 pmI tried deinterlace but it’s the same. Twitching in motion object, example a car move from left to right in video. My video is PAL system, lower field first. I tried with all options in deinterlace in TMPGENC but it’s same.
