Activity Forums Compression Techniques Need software advice for matching delivery specs
  • Need software advice for matching delivery specs
    Posted by Justin Schultz on February 4, 2015 at 5:13 pm
    Hello,
    We will be delivering programming for broadcast in a “PAL” environment. I don’t have experience encoding for xd5c and i’m not sure which encoding platform will be able to satisfy the requirements. I have dug through my available options in both Compressor and Adobe Media Encoder and have found many of the specs required but not all.
    My main question then is, provided the specs below, which software will be needed? Is it possible that some of the specs listed are just assumed in an application where i don’t see a specific option to select it and therefore able to match the specs?
    TL;DR – Do i need Telestream Episode Pro?
    Video
    Format : MPEG Video
    Commercial name : XDCAM HD422
    Format version : Version 2
    Format profile : 4:2:2@High
Format settings, BVOP : Yes
    Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
    Format settings, picture structure : Frame
    Codec ID : xd5c
    Duration : 3mn 3s
    Bit rate : 50.0 Mbps
    Original width : 1920 pixels
    Original height : 1080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Interlaced
Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.997
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Audio
    Format : PCM
Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 3mn 3s
Bit rate mode : Constant
    Bit rate : 1536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Thanks in advance
    Daniel Fletcher replied 11 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Eric Strand
    February 5, 2015 at 3:06 am
    It looks like they need a XDCAM HD422 1080i50 file. Which NLE are you editing in. I know FCP 7 had an option to export to XDCAM.
    @ericstrand11
  • Justin Schultz
    February 5, 2015 at 3:26 pm
    Thanks for the reply.
    I’m editing in PPro CC.
    Yes, it does seem like that is what they want. However the XDCAM HD 422 1080i50 presets in AME are missing many of the line items listed in the specs, e.g.:
    Video
    Color space: YUV
    Compression mode: Lossy
    Bits/(Pixel*Frame): 0.997
    Audio
    Codec ID: sowt
    Or the ability to set the audio bitrate to 1536kbps
    Wrapper is a little vague in the specs but all of my options are different in AME whether i choose .mpg, .mxf, or .mov
    I was hoping someone could tell me that some of these specs are assumed in certain settings or referred to as something else. Or if they knew whether Episode Pro would display more of the spec line items.
    I will probably download the trial of Episode Pro to see if that answers my questions, while setting up some test deliveries from my AME choices.
    It’s a tough topic to not be verbose with! Thanks for reading.
  • Eric Strand
    February 6, 2015 at 3:04 pm
    Hi Justin, those settings are assumed. I just did a test here with Media Encoder and choosing Format: Quicktime, then codec XDCAM HD422 1080i50 output settings that matched. Make sure you changed your audio settings to uncompressed. When I output an MXF, the audio bitrate was a bit lower, so they must want an .mov.
    @ericstrand11
  • Justin Schultz
    February 6, 2015 at 6:51 pm
    Thanks so much for the reply Eric. Very helpful and much appreciated.
  • Manny Kivowitz
    April 1, 2015 at 3:21 pm
    Super helpful thread but unfortunately the one thing that Justins specs didn’t include which the specs we received, for 10 different major markets in the US via Comcast, was requirement of embedded (not sidecar) closed captioning in the MPEG 2 file.
    The specs for our 12 individual PSA’s also required encoding for both HD & SD – both in mpeg 2. The SD specs were slightly different of course but similar overall.
    After trying Adobe Media Encoder (which won’t output closed captioning to mpg) and Episode Pro (which also wouldn’t output embedded closed captioning), as well as trying encoding.com and Amazons Elastic Encoder – both of which we failed to get successful results from, we finally decided to go to an outside vendor to run the final deliverables from ProRes HQ masters (seperate masters for HD & SD). The vendor, Sycro in NYC, used Telestream’s enteprise grade system, Vantage to do the job.
    It just seems unreal to us that in 2015, formats that have been used by broadcasters for years are not included in Pro encoding software.
    The final kicker was that when we received the encoded files back from the vendor, we could not check the closed captioning properly without having to purchase a player like Switch or Drastic Preview.
    If anyone has any thoughts on the above, we’d love to hear them!
  • Craig Seeman
    April 1, 2015 at 4:00 pm
    [Manny Kivowitz] “The vendor, Sycro in NYC, used Telestream’s enteprise grade system, Vantage to do the job.
    [Manny Kivowitz] “Episode Pro (which also wouldn’t output embedded closed captioning)”
    I believe Telestream is listening.
    [Manny Kivowitz] “t just seems unreal to us that in 2015, formats that have been used by broadcasters for years are not included in Pro encoding software.”
    One may well do this in 2015.
    [Manny Kivowitz] “we could not check the closed captioning properly without having to purchase a player like Switch”
    Probably not a feature you’d find in a free player. Development involves resources and the market is small so returns on development investment have to happen.
  • Daniel Fletcher
    April 7, 2015 at 4:33 am
    Have you called the broadcaster directly and spoken with the people that will receiving your files?
    They may be able to offer you some insight, suggest an encoder or offer you other options.
