Activity › Forums › Adobe After Effects › Need response ASAP! Will the quicktime render of a 9GB after effects animation playback normally in final cut?
  • Need response ASAP! Will the quicktime render of a 9GB after effects animation playback normally in final cut?
    Posted by Allison Pichert on June 5, 2009 at 3:01 pm
    I am working on the title animation sequence of a film. After rendering the sequence to quicktime, it comes to be a 9GB file.
    The file is too large for the computer to handle and playback in quicktime stutters.
    BUT, when I open after effects, import the (stutter-y) quicktime file and RAM preview, it plays smoothly. Although, the RAM preview also appears to only be able to handle 7 seconds.
    When I import the quicktime into Final Cut, it stutters and claims drop frames. It doesn’t require rendering in Final Cut either, though I tried.
    I need the animation sequence to play normally in final cut so it can be integrated with the rest of the film. So my question is, do I just trust that in the final rendering (putting back to tape or burning to a dvd) that it will play smoothly? Or do I need to be able to see it play smoothly in final cut.
    I don’t really have time to re-render out of after effects (unless absolutely necessary).
    It’s just weird that it would be fine in ram preview of after effects (albeit for only a short clip before it stops) and no where else.
    I need this today, so any response asap would be helpful. Thank you!!!!
    Allison Pichert replied 17 years, 3 months ago 28,668 Members · 1 Reply
